JUri not found
4 years 3 weeks ago #8032 by angelsweb
JUri not found was created by angelsweb
Hello,
I get this error:
0 Class "Visolutions\Component\Visforms\Administrator\Service\HTML\JUri" not found
While trying to Edit Data of User input of Form
Joomla 4.1.0
PHP 8.0.2
Visform base 4.1.4
Visform Subscription 4.1.2
Thank you
4 years 3 weeks ago - 4 years 3 weeks ago #8033 by Administrator AV
Replied by Administrator AV on topic JUri not found
Hi angelsweb,
I'm sorry for your trouble.
Due to the major code changes which were necessary in order to adapt Visforms to Joomla 4 there sadly are still a few bugs, especially in code sections which are rarely use.
We are in the middle of releasing a new Version of vfbase and vfsubscription and this will include a fix for this problem.
We hope to be able get the release out within the next two weeks.
This fix of the problem, which you report, only effects one line in administrator/components/com_visforms/src/Service/HTML/Visforms.php (line 111)
If you replace the JUri in this line (two times) with Uri the code should work again.
Old:
return '<a href="' . JUri::root() . $registryString . '" target="_blank">' . JUri::root() . $registryString . '</a>';
New:
 return '<a href="' . Uri::root() . $registryString . '" target="_blank">' . Uri::root() . $registryString . '</a>';
Last edit: 4 years 3 weeks ago by Administrator AV.
4 years 3 weeks ago #8036 by angelsweb
Replied by angelsweb on topic JUri not found
Thank you, that solved the error!
4 years 5 days ago #8066 by Administrator IV
Replied by Administrator IV on topic JUri not found
Hi angelsweb,
the bug is fixed in the latest release from 05.04.2022 for Joomla 4:
Visforms 4.1.5
Visforms Subscription 4.1.3
Greetings, Ingmar
