display separate text label in an URL field
3 years 8 months ago #8267 by bstanton
Is there a way to display text that is different from the URL?
the equivalent of :
Click
<a href=" somewhere.com ">​​​​​​​Here</a>  to go somewhere
3 years 8 months ago #8268 by Administrator IV
Replied by Administrator IV on topic display separate text label in an URL field
Hi bstanton,
Unfortunately, it's not entirely clear to me what exactly you intend to do there.
Where exactly is that supposed to be?
On the form, in one of the emails or in the PDF?
If you mean the field on the form itself, what exactly should it look like?
The field of type 'Url' is used to allow a user to provide a link that will be displayed later (email, PDF).
Best regards, Ingmar
3 years 8 months ago #8269 by bstanton
Replied by bstanton on topic display separate text label in an URL field
Hi, thanks so much for your reply. I wish to display a clickable link showing in the frontend. I see that I can enter eg. somewhere.com in the URL field. But I would like to display some other text as a clickable link that goes to somewhere.com . e.g. Instead of seeing " mayoclinic.com as a link, the user would see 'Mayo Clinic' as a clickable link, which would take them to " mayoclinic.com if clicked.
perhaps it can't be done? The text could come from another field in the same record.
thanks.
3 years 8 months ago #8272 by Administrator IV
Hi bstanton,
I am very sorry, but unfortunately this is not possible at the moment!
However, we think it's a really interesting feature, so we've added it to the feature wish list.
If this feature should be implemented and released, then you will be informed about it here in this post.
I'm sorry I can't give you another answer!
However, if you should have good developer skills, you can always integrate your own JavaScript into the page to find the affected links and change them according to your wishes.
The following user(s) said Thank You: bstanton
