published / unpublished link of data's do not work in frontend list view
3 years 7 months ago #8349 by sek101079
Hi there,
I am struggling with the front end list view which shows a green check mark (publish) for each table record and it looks like it should have a function to be able to change it to "unpublished". However this seems to not work. When I click on this check mark nothing is happening. A hyperlink seems to be there, but this hyperlink is not providing any result once clicking on it.
3 years 7 months ago #8351 by Administrator AV
Hi there,
yes clicking on the check mark should unpublish the record.
All known bugs were and will be fixed immediately and no problems are currently known.
So if you use Visforms, you can assume that any problem that arises is very much likely not due to errors or bugs related to Visforms itself.
The problem you describe is probably caused by a Javsacirpt problem.
Please make sure, that you have installed the latest versions of Visforms and Visforms Subscription on your website.
Please use the developer tools of your browser, in order to check, if there are some helpful (error) messages in the Console.
Please test, if the problem persists, if you use the Joomla default template (Cassiopeia).
Let us know, if you have any further information.
