SQL Listbox
3 years 4 months ago #8615 by DJGBN
Replied by DJGBN on topic SQL Listbox
<code> SELECT `XXX_visforms_24` as value, `XXX_visforms_24` as label from #__visforms_F186 ORDER BY `XXX_visforms_24` DESC </code>
Ich hab es mal so Versuch.
Fehler kommt Promt: 42S02, 1146, Table 'XXX.XXX_visforms_F186' doesn't exist
Aber das Feld ist Definitiv da und ich kann es ja mit dem anderen Code auslesen.
3 years 4 months ago #8616 by prffrost
Replied by prffrost on topic SQL Listbox
SELECT F122 as value, F122 as label from #__visforms_2 ORDER BY F122 DESC
#__visforms_2 = Tabelle bezw Formular ID
F122 = ist die ID des Feldes
The following user(s) said Thank You: Shaman, Administrator IV
3 years 4 months ago #8619 by DJGBN
SUPER DANKE. Das hat geklapt. VIELEN DANK
Gruß Marcel
