Remove Powered by vi-solutions link
12 years 10 months ago #230 by jasons
Remove Powered by vi-solutions link was created by jasons
Hello - First off I just want to say this is are great extension! This will supply everything I need to create mailing list and contact us forms.
Does vi-solutions allow for the Powered by vi-solutions link on the bottom of each form to be removed? If so how do I go about doing that?
Thanks again for this great extension!
12 years 10 months ago #233 by Administrator AV
Replied by Administrator AV on topic Re:Remove Powered by vi-solutions link
Hi jasons,
yes we do allow to remove the powered by link. I can absolutly understand, that you do not want to have the link in frontend.
Nevertheless, developing the extension took me hundreds of hours. So you may consider making a small donation (any amount is appriciated) to support the extension and it's further development (i.e. update to Joomla! 3) in a way, different from showing a link. (There is a donate button, just to the left).
To remove the link look in your form at the "Advanced" Tab. At the bottom is an option to remove the link.
Kind Regards,
12 years 10 months ago #235 by jasons
Replied by jasons on topic Re:Remove Powered by vi-solutions link
Thanks for the tip, I will make sure to make a donation!
