Custom Text Position above input
3 years 1 month ago #9011 by mojweb
Custom Text Position above input was created by mojweb
Im using textarea field in multistep form. Try to show Custom Text  above the field with seting Custom Text Position Above input.
If I select  Above input or Above leabel, allways custom text shows above label.
It works below input.
3 years 1 month ago #9015 by Administrator IV
Replied by Administrator IV on topic Custom Text Position above input
Hello mojweb,
in order to help you, we need the following information:
- which UI framework your template uses,
- which UI framework is set in Visforms (form configuration, tab 'Advanced', group 'Layout'),
- which sub-layout is set in Visforms, if any (form configuration, tab 'Advanced', group 'Layout'),
- a link to the form or the screenshots (would be very helpful).
The UI framework setting in Visforms must match the UI framework your template uses.
Visforms adapts to the chosen UI framework by rendering the appropriate and minimally necessary HTML.
The above settings are described in the documentation.
Adjust form layout by configuration:
docs.joomla-4.visforms.vi-solutions.de/e...ayout-configuration/
Subscription Layouts:
docs.joomla-4.visforms.vi-solutions.de/e...ubscription/layouts/
Kind regards, Ingmar
3 years 1 month ago #9022 by mojweb
Replied by mojweb on topic Custom Text Position above input
Using Helix Ultimate - Bootstrap 5.2. Working on localhost. I gues the sublayout is the problem?
3 years 1 month ago #9024 by Administrator IV
Hi mojweb,
Thank you for the detailed information about your settings.
With this we can reproduce the error.
There is practically only the variant above the label and below the input field.
Other layouts with similar settings are also affected (Bootstrap 4, Bootstrap 5 and UIkit 2 and 3 layouts).
It has nothing to do with the sub-layout setting.
This area is complex and not easy to correct without unwanted side effects.
So I can't say at the moment whether there will be a quick, simple solution (workaround).
I created a development issue for the bug list:
Issue [VF-747] Forum: Bug fix: Selection 'Above input': custom text shows above label
Thank you again for your report!
