Problems with date field default value and validation
2 years 11 months ago - 2 years 11 months ago #9215 by Administrator AV
Hi Nick,
I changed the subject, because I think, this is not a Edit View problem in the first place.
I hope this is okay with you.
Sadly I cannot reproduce your problem
I set up a test form with a date field.
In the field configuation on the tab "Basic Options" set up the following options.
Minimum date validation: A fix date
Minimum date: 04/01/2021
Maximum date validation: A fix date
Maximum date: 04/30/2021
Fill Field With: Fix date/Day date
Checkbox "Current date": checked
I display the form in Frontend, using a menu item of type Visforms Form.
When I open the form, the date field is prepopulated with the current date (04/24/2023)
When I just hit the "Submit" button, the Javascript validation kicks in and an error message is displayed (Please selec a date lower or equal to 04/30/2021)
The form cannot be submitted, until I select a date between the minimum and the maximum date, as they are set up in the field configuration.
If I circumvent the Javascript validation, so that I can submit the invalid date, then the php validation kicks in.
In this case, the form is redisplayed.
A php error message ist displayed.
The data are not stored in the database.
So with the correct field configuration, the problem you describe does not result.
I was wondering whether, maybe you just did not set up the field correctly?
Maybe you forgot to check the "Current date" option?
If you cannot find a problem in the field configuration, then I could take a look into the problem.
The question is, can you provide us with an Akeeba backup of the site, then?
We use the following platform for this purpose:
wetransfer.com
I actually would not use a default value for the field, but make it requiered instead.
But setting it up with a default value outside the range of a min/max validation should work and does work in my test.
Last edit: 2 years 11 months ago by Administrator AV.
