Accessibility violation: Ensures ARIA attributes are allowed for an element's ro
3 years 3 months ago #9330 by rusasadmins
When required fields are included in a form, the form triggers the following accessibility violation:
Ensures ARIA attributes are allowed for an element's role
Element Location
.field19
Element Source
<div class="field19 required" aria-required="true">
To solve this problem, you need to...
Fix the following:
ARIA attribute is not allowed: aria-required="true"
Examples of forms where this violation appears can be seen at:
* sociology.rutgers.edu/news-events/submit-news
* sociology.rutgers.edu/news-internal-source
* sociology.rutgers.edu/contact-us-symposium
* sociology.rutgers.edu/newsletter-submit-event
* edison.rutgers.edu/contact-us
Thanks,
Eddie
3 years 3 months ago #9333 by Administrator IV
Hello Eddie,
Web accessibility evaluation tools are software programs or online services that help you determine if web content meets accessibility guidelines.
Different aspects are to be considered when selecting these tools.
Web accessibility evaluation tools can help you quickly identify potential accessibility issues.
Human judgment is always required.
Sometimes evaluation tools can produce false or misleading results.
Different tools sometimes produce different results.
Could you please explain in more detail which tool you are using and probably which policy is being violated or which accessibility issue rises and how it happened according to the tool used?
Before we change code to set ARIA attributes, we want to be sure that what we're changing is correct.
Best regards, Ingmar
3 years 3 months ago - 3 years 3 months ago #9338 by rusasadmins
Hi, Ingmar,
Thanks for the reply.  The violation was detected using Deque axeMonitor and was reproduced using the axe DevTools plugin for Chrome.  When a page is scanned using these tools - for example, edison.rutgers.edu/contact-us - this error is reported for each instance of a required field in the Visform:
Elements must only use allowed ARIA attributes
more information:  dequeuniversity.com/rules/axe/4.7/aria-a...pplication=AxeChrome
Element Location:
.field11<div class="field11 required" aria-required="true">
To solve this problem, you need to fix the following:ARIA attribute is not allowed: aria-required="true"
In addition, the reCAPTCHA element returns the following accessibility violation:
<html> element must have a valid value for the lang attribute
Ensures the lang attribute of the <html> element has a valid value
more information: dequeuniversity.com/rules/axe/4.7/html-l...pplication=AxeChrome
Element Location:
iframe[title="reCAPTCHA"] html
<html dir="ltr" lang="en_gb">
Value of lang attribute not included in the list of valid languages
Thanks,
Eddie
Last edit: 3 years 3 months ago by rusasadmins.
3 years 3 months ago #9396 by Administrator IV
Hello Eddie,
we consider this a bug in Visforms and will adjust the behavior.
I created a development issue for the bug list:
Issue [VF-820] Forum: Accessibility violation: All control group DIVs having aria-required="true"
Thank you for your report!
Kind regards, Ingmar
3 years 3 months ago #9398 by Administrator IV
Hello Eddie,
there is a bug fix to fix the error.
Download the following files:
- vi-solutions.de/forum-bugfixes/jquery.validate.js
- vi-solutions.de/forum-bugfixes/jquery.validate.min.js
Use the files to overwrite the following files on the server:
-  media/com_visforms/js/jquery.validate.js
-  media/com_visforms/js/jquery.validate.min.js
2 years 11 months ago #9758 by Administrator IV
Hello Eddie,
the bug is fixed in the latest release from 12.10.2023 for Joomla 4:
Visforms 4.3.1
docs.joomla-4.visforms.vi-solutions.de/e...dates/version-4-3-1/
Visforms Subscription 4.3.1
docs.joomla-4.visforms.vi-solutions.de/e...s/sub-version-4-3-1/
