Label name not showing correctly
1 year 8 months ago - 1 year 8 months ago #11019 by akshehu
Label name not showing correctly was created by akshehu
Hi..
i tried to fix but could not find where to adjust it.
1. In the showing the data "As a list". The label and the data field is together without space or ":".
2. Instead of number , it is showing "Index" as count for the data submitted
How to correct this or is it a bug?
Thank you.
Last edit: 1 year 8 months ago by akshehu. Reason: i solved two of the issues. the last one is not solved
1 year 8 months ago #11023 by Administrator AV
Replied by Administrator AV on topic Label name not showing correctly
Hello,
thank you for your patience.
There is a detailed article about the 'As List' option in the documentation:
docs.joomla-5.visforms.vi-solutions.de/e...iew-one-below-other/
Quote
The layout
No CSS when selecting “List” option
It is our goal to enable the most versatile view of the data possible. Therefore, we have decided on the following. If you select the “List” option above, we do not add any CSS to the resulting view.
Well-structured HTML
Instead, we build the whole page with a very well-structured HTML. In it, all elements can be addressed meaningfully and directly via really simple CSS selectors.
Write your own CSS
This means that you write your own CSS to freely design the view according to your needs. Of course, there are also Visforms users who have not yet had much experience with CSS. For those users, below is a complete step-by-step CSS example that will be used to
bring the page into a nice looking shape.
In addition, the HTML structure is well documented there and there is a CSS example:
You can use the Frontend Webassets in order to add the CSS
docs.joomla-5.visforms.vi-solutions.de/e...assets/introduction/
