Speach Bubble Prompts
12 years 6 months ago #420 by jed keenan
Speach Bubble Prompts was created by jed keenan
How can I turn these pop-up prompts off as they are displaying really poorly on the site? www.bsujoomlaclub.org/index.php/feedback-form
12 years 6 months ago #421 by Administrator AV
Replied by Administrator AV on topic Speach Bubble Prompts
those pop-up's are the javascript validation result messages for your users, to help them fill in the form correctly. They pop up when a user makes an invalid input, i.e. leaving a required field empty or enter an invalid email into an e-mail field. They cannot be turned off.
They are displaying poorly because of css rules in your template.
try to add
.visforms table {
margin-bottom: 0;
.visforms th, .visforms td {
padding: 0;
to your template css or to visforms.css
The following user(s) said Thank You: jed keenan
12 years 6 months ago #422 by jed keenan
Replied by jed keenan on topic Speach Bubble Prompts
I inserted the code but it had no effect so I reduced the padding to 0 but still get a one pixel gap between the td.t and td.c
th, td {
padding: .0em 0em;
text-align: left;
vertical-align: top;
12 years 6 months ago #423 by Administrator AV
I looked on Firefox and Google Chrome. Can't see a gap. For it's a css problem related to your template please use some developer tools (firebug, chrome developer tools, IE developer tools) to check where the gap you see stems from.
12 years 6 months ago #424 by jed keenan
Yep, its only appearing in Chrome. Thanks very much for helping to narrow this issue down for me.
