How can I reply to sender
12 years 2 weeks ago - 12 years 2 weeks ago #476 by stampgo7
How can I reply to sender was created by stampgo7
Hello there,
first of all let me thank the creator of this grate extension.
I have a site for searching and booking accommodation and I have a problem:
When a visitor choose a hotel and sent request to the owner it is ok. What should I do in the parameters in order when the owner click the reply button, to reply straight to the visitor (who is the sender) and not reply to my sites e-mail?
Thank you.
Last edit: 12 years 2 weeks ago by stampgo7.
12 years 2 weeks ago #477 by Administrator AV
Replied by Administrator AV on topic How can I reply to sender
Hi stampgo7,
sadly that is just not possible yet. It's annoying, I know, and I made it a point on my todo list. It will come in future versions.
The following user(s) said Thank You: stampgo7
12 years 2 weeks ago - 12 years 2 weeks ago #478 by stampgo7
Replied by stampgo7 on topic How can I reply to sender
Thank you for your quick reply.
I will be waiting for you to solve that issue.
George
12 years 1 week ago - 12 years 1 week ago #479 by Administrator AV
Hi guys,
there are so many request for this feature that I will give a description how to fix it here. I will include this changes into the source code of Visforms and they will be part of the next release. So you can make the following changes to the code without fear of loosing them on the next update of Visforms.
The changes are the same for visforms 2.0.x and 3.0.x. They are not meant for Visforms 1.0 Versions!
Go to components/com_visforms/models/visforms.php, make a backup copy of this file and open it.
At about line 808 you find the section "Send Email Result"
find the line
$mailBody = $mailBody."registered at ".date("Y-m-d H:i:s")."<br /><br />\n\n";
(about 5th line in the first if statement)
replace it with
$mailBody = $mailBody."registered at ".date("Y-m-d H:i:s")."<br /><br />\n\n"; $emailSender = "";
find the line
$field = $visform->fields[$i];
(just 2 or 3 lines below, right at the top of the following for-Statement)
replace it with
$field = $visform->fields[$i]; if ($field->typefield == 'email') { if (isset($field->postValue)) { $emailSender = $field->postValue; } }
find line
$mail->setSender( array( $visform->emailfrom, $visform->emailfromname ) );
about 50 lines below but before "Send Email Receipt" section
Replace it with
if ($emailSender == "") { $emailSender = $visform->emailfrom; } $mail->setSender( array( $emailSender, $visform->emailfromname ) );
That's it.
Good luck and kind Regards,
Last edit: 12 years 1 week ago by Administrator AV.
12 years 1 week ago - 12 years 1 week ago #480 by stampgo7
Hello again,
the line
does not exist
I can find this similar line:
$mail->setSender( array( $visform->emailfrom, "" ) );
and if I do all the corrections you say the site crashes.
Is there a way to attache the file?
George
Last edit: 12 years 1 week ago by stampgo7.
12 years 1 week ago #481 by Administrator AV
which Version Visforms do you use? Check in Extension Manager -> Manage please.
You can send me the file to my contact e-mail which you can find below the forum.
