Module enhancement - Submit/reset buttons
12 years 2 months ago #649 by JohnDough
Would it be possible to add a tooltip feature to the submit and reset buttons? It would be really helpful for adding terms of submitting to this before they click on "Submit". "Reset" is not that important but a handy warning could help users.
Amateur "Bug" Writer
12 years 2 months ago #650 by Administrator AV
Replied by Administrator AV on topic Module enhancement - Submit/reset buttons
Hi John,
I will consider that, but there are already different options to make sure a user knows the terms.
You can add a Custom Text to every field (tab advanced). Usually the text is displayed beneath the field in case of buttons it's display above the buttons.
When you create a field of type "field separator", check the "border not visible" option and type in a custom text for that field, you can use it, to display a custom text almost everywhere in your form.
I usually create such a field separator field and below that a field of type checkbox "I know the terms and agree..." which I make a required field.
This way you can be sure, the user has noticed the terms.
Kind Regards,
The following user(s) said Thank You: JohnDough
