[Help] Erorr when submission
11 years 1 week ago #1414 by ingusan
[Help] Erorr when submission was created by ingusan
Hi evrybody, Sorry for my bad english.
I found this error when try to submit same (identic) ID. How to fix this error?
"Fatal error: Call to a member function enqueueMessage() on a non-object in /home/[mydomain]/public_html/[mysubdomain]/components/com_visforms/lib/business.php on line 290
Thanks before .
11 years 1 week ago #1415 by Administrator AV
Replied by Administrator AV on topic [Help] Erorr when submission
thanks, you found a bug in Visforms. I will fix it with the next release!
To make it work for you please open the file components/com_visforms/lib/business.php
find line 290 which causes the error
$app->enqueueMessage(JText::sprintf('COM_VISFORMS_UNIQUE_VALUE_REQUIRED', $this->field->label, $this->field->dbValue));
Replace it with
$app = JFactory::getApplication(); $app->enqueueMessage(JText::sprintf('COM_VISFORMS_UNIQUE_VALUE_REQUIRED', $this->field->label, $this->field->dbValue));
That should fix the problem.
The following user(s) said Thank You: ingusan
11 years 1 week ago #1416 by ingusan
Replied by ingusan on topic [Help] Erorr when submission
Thank you Aicha, its Work and solved my problem. :)
