Dataview not publishing?
10 years 8 months ago #1840 by swellking
Dataview not publishing? was created by swellking
Hello,
Sorry I don't speak German. I have installed Visiforms and the Dataview plugin so I can display inputed data on the front end. I enabled the plug in and checked and double-checked the syntax and it does not display the content. I only see the syntax on the front end.
Any suggestions?
Thanks
10 years 8 months ago #1842 by Administrator AV
Replied by Administrator AV on topic Dataview not publishing?
I'm sorry for your trouble.
Could you please send me a link (if you like to you can mail it to contact@vi-solutions.de) to the data view in front end..
Although you double-checked the syntax I think that it is most probably a syntax problem and I think the first step to help you would be, if I check the syntax, too.
10 years 8 months ago #1861 by Administrator AV
After a closer look it turned out, that the plugin was used in a module.
If you use a content plugin in a module you have to enable the "Prepare Content" Option in the "Options" tab.
