Replay-to wrong
10 years 3 months ago #2238 by kallehk
Replay-to wrong was created by kallehk
I am running Visforms 3.5.7 on joomla 3.4.5 with php 5.6.14.
The problem is that the "replay-to"-address in the sent email has a different "from"-address so the email get stuck in spam filters.
There is no way in the fields in visforms to define what replay-to-address should be used(why is there a replay-to in the mail in the first place?). Instead the email used is the one the user enters in the email field!
If I remove the email field the result email is delivered but then user wont get a recipient mail!
Include data is checked both for result and recipient mail.
10 years 3 months ago #2239 by Administrator AV
Replied by Administrator AV on topic Replay-to wrong
actually using the user mail address from form inputs as reply to address and not as mail from address was introduced in order to prevent mails from being flag as spam. Since I made these changes, reports of mails being flag as spam are reduced to almost zero. I think, that you would run into the same problem, if the user mail address would be used as mail from address. Please contact your provider to find out how to solve this problem.
10 years 3 months ago #2246 by kallehk
Replied by kallehk on topic Replay-to wrong
Yes, I was totally wrong about the replay-to. After talking to the provider it seems that the spam-checking engine is reporting a BODY_URI_ONLY on the email and as I understand it, it is the following line that screws with spamassasin:
<a href="mailto:xxxx@xxxx.de">xxxx@xxxx.de
Is there any way to exclude that line from the body ? As the email address is already present in the header there is no need for it in the body.
10 years 3 months ago #2248 by Administrator AV
thanks for this reply.
It is really difficult to create mails which are conform with every spam protection software. Every piece of information about what can go wrong, helps to improve Visforms as well!
At the moment there is no clean way to remove that ancor but you have two "unclean" options to do it.
First. Disable the "Include Data" Option for the result mail. Use the Placeholder feature of Visforms and add the data which you want to be send with the mails manually in the editor field for "Result Mail Text". (Not so nice if you have a form with many fields or many forms...)
Second. Find the file components/com_visforms/models/visforms.php
find the
private function sendResultMail($visform)
in this file
find the following code in this function
if ($field->typefield == 'email') { $fieldValue = '<a href="mailto:'.$fieldValue.'">'.$fieldValue.'</a>'; }
and comment it
/*if ($field->typefield == 'email') { $fieldValue = '<a href="mailto:'.$fieldValue.'">'.$fieldValue.'</a>'; } */
(or simply remove it)
If this code passage causes the Visforms result mail to be flagged as spam, I think I have to make an adaptation for the next Visforms release. I will either add an option to control whether or not a link will be added to the mail or will simple remove this code.
The following user(s) said Thank You: kallehk
10 years 3 months ago #2261 by kallehk
It did not work by removing the code. The email-address were still in the email. But I changed it to:
if ($field->typefield == 'email') { $fieldValue = ' '; }
Now it is working. Many thanks!
10 years 3 months ago #2262 by Administrator AV
thanks!
