exporting fields
9 years 10 months ago #3021 by mligrani
exporting fields was created by mligrani
:ohmy:
hi guys,
is it possible to export the "created by" field displayed in the data page? it's very critical to us..
thank you in advance,
regards
massimo
9 years 10 months ago #3024 by Administrator AV
Replied by Administrator AV on topic exporting fields
at the moment it is not. I think, when I added the created_by field in Visforms I just "forgot" to add an option which would allow you to include/exclude the field from export.
I could add such an option in the next release.
If you just need to have this field in all your exports (without a form configuration option to set whether it is included or not) you can change the source code.
Open the file administor/components/com_visforms/models/visdatas.php
find the function createExportBuffer ($params = null, $cids = array())
find
if (isset($params->expfieldcreated) && $params->expfieldcreated == 1) { $buffer .= JText::_( 'COM_VISFORMS_FIELD_CREATED_LABEL' ) . $separator; }
and add the line
$buffer .= 'Created By' . $separator;
directly after this code. (In order to have a label in the haeder, if you export with a header
Find the function createPreFields ($params, $row, $separator = ";")
find
if (isset($params->expfieldcreated) && $params->expfieldcreated == 1) { $data .= $row->created . $separator; }
Add
$data .= $row->created_by . $separator;
directly after this code (this will add the userid to each export row).
It's not tested yet, but I think, this will work,
The following user(s) said Thank You: mligrani
9 years 10 months ago #3027 by mligrani
Replied by mligrani on topic exporting fields
Hi Aicha, it worked perfectly.
Going to rate your work on JED. Donation will come with the next release, including ID and/or user data export configuration in the administration panel... ;)
thank you very much by now
massimo
9 years 10 months ago #3029 by Administrator AV
Thanks,
I already added a new option "included created by" to the Visforms core.
So the changes will be part of Visforms 3.8.2.
But I think it will take me some more time to release this update because I actually wanted to add some other feature to this release as well.
