Result and background
9 Jahre 4 Monate her #4205 von veganway
Result and background wurde erstellt von veganway
Hello,
I have two questions. After someone sends a message through the form, I'd like a message like "Thanks for your message, we'll contact you asap" to be displayed, but in the same page where the form is present, while now I see a message (that I set in "Text result") but all the rest of the page disappears and if I navigate to another page and then go back to previous page, I see a blank page. Is it possible to solve this?
Also, how can I put the fields in a grey box/background area like in this form here on the Forum?
Thank you!
Chris
9 Jahre 4 Monate her #4209 von Administrator AV
Administrator AV antwortete auf Result and background
the first thing is not possible with Visforms. You can either use the default message, which will always be displayed at the front page (home menu item) or you can use a custom result text, which is a separate "page" created by Visforms or you can use a redirect url, i.e. to an article of your choice. Then the article must provide the "result text".
How the form and fields "look" is mostly determined by the css of your template. You can add custom css, in order to adapt this. There is an article in the documentation about this: www.vi-solutions.de/en/documentations/vi...form-layout-with-css
8 Jahre 10 Monate her #4751 von Administrator AV
Hi Chris,
the latest Visforms Subscription will add some additional redirect options to Visforms. Please check out the documentation
www.vi-solutions.de/en/documentations/do...ion-redirect-options
If this is what you were looking for and you are interested in using the feature you need a Visforms Subscription.
Please check out this article, too, because the latest Visforms Subscription is released with a stablitiy level "Release Candiate".
www.vi-solutions.de/en/documentations/do...el-release-candidate
