Field order
8 Jahre 11 Monate her #4649 von envisys
Field order wurde erstellt von envisys
How can I change field order in a form?
8 Jahre 11 Monate her #4650 von Administrator AV
Administrator AV antwortete auf Field order
Visforms uses the Joomla! standard way for ordering fields. (It is just like changing the order of Joomla! articles in the Content -> Articles view for example.)
Click the table header of the ordering column (leftmost column in the view, two small triangles) and than change the field order with drag & drop.
8 Jahre 11 Monate her #4651 von envisys
envisys antwortete auf Field order
I tried but It don't work.
I see the tolltip that inform you about drug and drop function, but It don't work. I Just can select some text.
8 Jahre 11 Monate her #4652 von Administrator AV
The tooltips are always visible but if you actually want to change the sort order, you must click the table header first. Those three stacked squares in each "field" row, will then change color to black. Before you have clicked the proper table header, they are gray (= disabled).
8 Jahre 11 Monate her #4657 von envisys
My fault... you are right! (>_<)
Now it works
