Submission Failure
6 Jahre 1 Monat her #6645 von Chicitadel
Submission Failure wurde erstellt von Chicitadel
Hello Aicha,
I created a form to capture association's data using VisForms but the submission process is failing with the following error
Form submit failed Please select no more than 1 option(s) for field "Country of Nationality".
However, the Country of Nationality has no conditions related to number of selection. I have also tried to alter the field name except the required condition.
I also use Jotcache and JCH Optimizer to improve the site speed.
What is the possible cause? Please I need help on this.
6 Jahre 1 Monat her #6646 von Administrator AV
Administrator AV antwortete auf Submission Failure
you probably have two or more options in your Country of Nationality field, that have the same option value.
This would be an invalid field configuration, which would result in exactly this error message.
6 Jahre 1 Monat her #6648 von Chicitadel
Chicitadel antwortete auf Submission Failure
Hello Aicha,
That is exactly what happened,
I had a field listed twice which triggered the error, resolved now.
Thanks
