some options doesn't work
3 Jahre 11 Monate her #8264 von naderfarid
some options doesn't work wurde erstellt von naderfarid
Hello.
I have a few problems with the settings that I couldn't fix. I hope you can help me.
Website: [url] inlc.net/index.php/blog/dadkhast [/url]
To explain the problems, I should have shown them on the picture. For better understanding, please look at the numbers on the pictureNo. 1 in the image:  If I activated the "Hide label" option, again, the label inside the field will be displayed!!! It's like I have activated "Tool Tip Text” While I did not.I want to hide the label with the empty field because I want to label shown in red color in bold text While there is no such possibility in the system that is why I'm using the custom text for the label in color and bold.No. 2 in the image: I don't know why there is no gap between "Textarea" and the above red border? I tried to fix that white giving extra space to the bottom of the border but doesn't work?No. 3 in the image: The system automatically creates unordered sizes in the fields and does not place any below each other in an orderly column. This causes irregularity in the form, which is not pleasant.
No. 4: Is it possible to use another editor like yours instead of the one installed in the system? How should it be changed?
If you need username and password, to access to admin panel, please me know.Thank you
3 Jahre 10 Monate her #8265 von Administrator AV
Administrator AV antwortete auf some options doesn't work
1. showing the label as hint inside the input, is how the feature "hide label" is supposed to work.
In contrast the "Tool Tip Text" is displayed as a popover, when somebody hovers over the input.
The "Tool Tip Text" is something completely different.
If hiding the label would just hide the labet, it would very easily be possible to create a field without label and without hint.
Then the user would not know, what they have to enter.
That is why we decided on displaying the label as hint then.
I think, this is actually all explained in the field description in the administration.
If you want the field label to be displayed in red or bold or something like that, you can use custom CSS.
You can use the CSS selector .visform in order to only apply CSS to a Visforms form.
2. You use a table element, in order to add your custom text.
In order to get some space to the editor, just add a margin-bottom to that table element.
3. Most of the unordered size is caused by the table elements in which you put your custom texts. You could add a width="100%" to these tables, that would fix the problem with the uneven text boxes.
Only the uneven display of the editor comes from Visforms itself.
HTML only provides the fieldtype textarea.
Displaying an editor instead, is actually a bit more complicated and in some cases the results are not 100% satisfying.
Please try, if this custom CSS fixes that problem for you.
.visform.bt5 .tox.tox-tinymce {
  width: 100% !important;
4. It is not possible to use another editor.
