Visforms, "Column checked_out can not be null"
1 Jahr 5 Monate her - 1 Jahr 5 Monate her #10915 von Bronco
Visforms V5.1.2
Joomla V5.2.1
PHP V8.2
Problem nr 1:
In admin side I click Data of a form to edit. Then when I ONLY click the Close-button, NOT Save & Close-button, I get that error. It works when I use the Save & Close-button.
I can also view the details without problems.
Problem nr 2:
In Frontpage and trying to edit I get 404 Page not found. But that is only for one form. Other forms works.
I tried to edit in admin side and saved and tried again to open the same data in Frontpage but still gets the same error.
Both of these problems is for the same form I setup and it worked earlier as it should before I updated Visforms. It works on the others forms I have without any problems. Before update I installed vfsubscription_j4.0.0_4.4.3.zip
/Thomas
Letzte Änderung: 1 Jahr 5 Monate her von Bronco.
1 Jahr 5 Monate her #10916 von Administrator IV
Administrator IV antwortete auf Visforms, "Column checked_out can not be null"
Hello Thomas,
the error '1048 Column checked_out cannot be null' was a known error in earlier versions.
It does not occur on any other Visforms installation.
When updating to the latest Visforms versions, SQL statements are run and the Visforms tables are adjusted accordingly.
The error is then resolved.
If these SQL statements did not run successfully for you, for whatever reason, you can try to run the SQL statements manually afterwards.
Run the following SQL statements in one go:
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO"; SET time_zone = "+00:00"; ALTER TABLE `#__visforms` modify checked_out int unsigned null; ALTER TABLE `#__visforms` modify checked_out_time datetime null; ALTER TABLE `#__visfields` modify checked_out int unsigned null; ALTER TABLE `#__visfields` modify checked_out_time datetime null; ALTER TABLE `#__vispdf` modify checked_out int unsigned null; ALTER TABLE `#__vispdf` modify checked_out_time datetime null;
The two SQL statements
are only sometimes necessary under certain database server settings.
In most cases they are not absolutely necessary.
Adaptation to your database:
Change the following into the above SQL statements.
#__ --> Your Joomla table name prefix.
The error should then be resolved.
Best regards, Ingmar
1 Jahr 5 Monate her #10917 von Bronco
Hi, nope didn't work. Same errors. I saw the same errors report in this forum earlier but that seemed to work when the user clicked Save & Close-button. For me it happens only when I click the Close-button.
1 Jahr 5 Monate her #10918 von Bronco
Hi again.
It did work. I just hade to change all the "#__visforms_*" too :P
1 Jahr 5 Monate her #10919 von Administrator IV
Hello Thomas,
I'm very happy that it worked.
Both processes and error messages mentioned here lead back to the same fact that 'null' values ??were suddenly allowed in the affected field during Joomla development (Joomla 4).
By explicitly allowing 'null' values ??in the table design, this fact is taken into account.
The SQL statements usually do this automatically with a total of 6 Visforms tables during the update.
Could you perhaps briefly list at least one of your changed final SQL statements here?
Simply so that it is clear what exactly you have changed and how?
Best wishes, Ingmar
1 Jahr 5 Monate her - 1 Jahr 5 Monate her #10928 von Bronco
Sure,
First I did what you wrote. Then this:
ALTER TABLE `d70do_visforms_2` modify checked_out int unsigned null; ALTER TABLE `d70do_visforms_2` modify checked_out_time datetime null; ALTER TABLE `d70do_visforms_8` modify checked_out int unsigned null; ALTER TABLE `d70do_visforms_8` modify checked_out_time datetime null;
And so on.
I probably didn't need to change all the forms I had since it was only one that "malfunctioned".
/Thomas
