Display number of records
8 Monate 1 Woche her - 8 Monate 1 Woche her #11749 von PFS_hansi
Display number of records wurde erstellt von PFS_hansi
I want to display the number of records from the form with ID 2 and with fieldID 29 = "My Headline"
How can I do this?
{vfdataview}{"formid":"2","fieldselect":{"29":"My Headline"},"count":"1","displaycounter":"true","sortorder":"created","sortdirection":"desc","show_page_heading":"false","showlabel":"false","layout":"list"}{/vfdataview}
rg
Hansis
Letzte Änderung: 8 Monate 1 Woche her von PFS_hansi. Begründung: Rechtschreibfehler
8 Monate 1 Woche her #11750 von Administrator AV
Administrator AV antwortete auf Display number of records
Hi Hansis,
The Data View plugin is used to display the records submitted for a form.
The plugin's configuration allows you to specify which fields the data is displayed for, how many records are displayed on a page, whether search filters are enabled, and similar settings.
The plugin cannot be used to aggregate data content.
For example, it cannot be used to count the number of records.
One way to achieve your desired goal would be:
- Create a new form
- This form has exactly one field of type Listbox SQL (and no submit button)
- Activate the 'Display as Data List' option in this field.
- Write an SQL statement that counts the number of records in the desired form for which the desired field is not empty
- Display this form using the Form View plugin in the same location where you are currently using the Data View plugin.
Folgende Benutzer bedankten sich: PFS_hansi
