Not possible to change input text field width
10 Jahre 6 Monate her - 10 Jahre 6 Monate her #2629 von kaza66
HI,
I am using newest VisForms with bootstrap grid supporting template.
Problem I got is I am not able to change the input field width in multicolumn layout(two columns only).
The link to the form page is:
medi-serv.eu/index.php/fuer-bewerber/ihr-profil
I tried to ON/OFF the option "Load Bootstrap Form CSS" but it didn't help.
In both cases using "template bootstrap.css" and "VisForms bootstrap.css" .
Strange is it works with textarea but in this case the Label Options/Hide Label option is not available.
I tried also to play with "CSS Class For Field" with " spanX" option but it makes no changes.
When I used " offsetX" option it worked properly and it moved input field textbox to different place.
Any idea what may be the issue ?
Thanks
Letzte Änderung: 10 Jahre 6 Monate her von kaza66.
10 Jahre 6 Monate her #2634 von Administrator AV
Administrator AV antwortete auf Not possible to change input text field width
as I wrote in the Documentation, multi column layout may not work on all websites as expected and requires that the template implements a bootstrap grid layout supporting class="spanX" attributes.
If you like to, I can check into this even if the result might be, that it is not possible with your template to us the multi column form layout. But maybe you just made a mistake in the configuration of the fields.
With regards to the amount of request in this forum and on mail, it is understandable, that I sadly cannot give support on individual configuration for free. I therefore created a support ticket .
10 Jahre 5 Monate her #2781 von visf_frank
ich habe das gleiche Problem mit dem mehrspaltigen Formularlayout.
Ich verwende das t3-bs3-template von Joomlart in der Version 2.2.1.
Meine Visforms-Version ist 3.6.11, der Link zu meiner Seite ist:
[url=http://] www.bbw-bezirk1.de/index.php/kontaktformulare/sportwart [/url]
Vielen Dank
Thomas
10 Jahre 5 Monate her #2782 von visf_frank
sorry, ich habe das Problem inzwischen gelöst. Das t3-bs3-Template läuft mit Bootstrap3. Aktiviert man hier auch noch Bootstrap 2, klappt alles wie gewünscht.
Thomas
10 Jahre 5 Monate her #2784 von Administrator AV
Hallo Thomas,
schön, dass du das Problem lösen konntest und das du die Lösung hier gepostet hast. Danke!
Folgende Benutzer bedankten sich: visf_frank
