Chrome issue - condition field
9 Jahre 8 Monate her - 9 Jahre 8 Monate her #3483 von dagsvic
dagsvic antwortete auf Chrome issue - condition field
Thanks for the info.
Correct I only got the form once from ur submission.
The cache I will adjust as I do have that particular form in module.
If I just link through menu do I need to disable cache somewhere else too?
*** You have been fantastic at assisting. I really appreciate it. ***
I'm nearly done at getting it working I think.
Edit: I just cleared the module/menu item from system cache if u want to try more.
Letzte Änderung: 9 Jahre 8 Monate her von dagsvic. Begründung: Update to cache
9 Jahre 8 Monate her #3484 von Administrator AV
Administrator AV antwortete auf Chrome issue - condition field
the different ways to publish the form (module versus menu item of type Visforms) and the different cache options and forms Joomla! provide (System Configuration and Cache Plugin) and there changes throughout the Joomla! Versions are really very complex.
I wrote an article about that in the documentation www.vi-solutions.de/en/documentations/vi...forms-caching-errors and I hope this article is still fully correct.
According to this article you can enable the system cache plugin if you publish the form via menu item of type Visforms and you can enable cache in the system configuration but only with the option "conservative caching". But I fear you have to test that. :)
Folgende Benutzer bedankten sich: dagsvic
9 Jahre 8 Monate her - 9 Jahre 8 Monate her #3488 von dagsvic
Ok..... So turned off System Cache Plugin.. Turned off Configuration Cache...
All seems to work now with multiple repeats at trying to send form submit..
However if i turn on either of the cache it wont allow it to do multiple attempts without refreshing (CTRL/SHIFT/R) to reset browser cache..
Strange i think.. But i will see how the site runs without cache..
I ended up setting up .htaccess for cache and see how that goes..
Feel free to trial again at multiple form submits if you get a chance.. Don't mind you playing.
I have also fixed the .js issues too... Well i think i have..
let me know if you find any issues..
EDIT -- Ok i activated the System Cache Plugin (using the visform module within article) and i can multiple submit different entries into form with no issues..
Letzte Änderung: 9 Jahre 8 Monate her von dagsvic. Begründung: upd to cache settings
9 Jahre 8 Monate her #3492 von Administrator AV
I tested several time reloading the form in chrome and everything seems to work. Submitted the form twice with success. So I think this is working now.
I wish you the best of luck.
