multi check box in ver.2.1.2
10 Jahre 5 Tage her #3502 von stavroch
multi check box in ver.2.1.2 wurde erstellt von stavroch
I have Joomla 2.5 and I install the Visforms Version 2.1.2.
How can I add check boxes with multi choices?
I use the check box group in your latest versions. What about the old versions?
10 Jahre 5 Tage her #3503 von Administrator AV
Administrator AV antwortete auf multi check box in ver.2.1.2
the field type checkbox group was developed in a later Version of Visforms.
As Joomla! 2.5 is no longer supported by Joomla! itself, there is no further development for Visforms Version which run on Joomla! 2.5, too and no support either.
It's just a courtesy that I still provide the download of the latest Visforms version for Joomla! 2.5 (because you you have to update Visforms on Joomla! 2.5 to this version, before updating to Joomla! 3).
It is strongly recommended to update to a save current Joomla! Version.
10 Jahre 5 Tage her #3504 von stavroch
stavroch antwortete auf multi check box in ver.2.1.2
Can you please provide me the url of the latest component?
10 Jahre 5 Tage her #3505 von Administrator AV
Please check out the downloads menu. You will find the latest version for Joomla! 2.5 there.
10 Jahre 5 Tage her #3506 von stavroch
I have install the version 2.1.2. Is that the latest version?
Can you please let me know what is the latest version number?
10 Jahre 5 Tage her #3511 von Administrator AV
yes this is the latest Version for Joomla! 2.5
