Bug: top field options like "hide label" do not appear
  • michaelh@notabandoned.org
  • Autor
  • Offline
8 Jahre 6 Monate her #4821 von michaelh@notabandoned.org
Bug: top field options like "hide label" do not appear wurde erstellt von michaelh@notabandoned.org
Hi - this happens occasionally and now seems to be sticking where the top field options disappear. Hide Label option for example is not there. this is for all fields. I cannot attach an image here to show but basically when looking at the Basic Options tab for any field on the right side the "Required" checkbox is the option shown. Anything above this is not showing for any of the fields.
8 Jahre 6 Monate her #4822 von Administrator AV
what Joomla!, Visforms and Subscription version have you installed?
Have your cleared javascript files in your Browser cache after the last Visforms update?
Are you aware, that the Label Options and Placeholder Options are only available for "Text" fields (like fieldtype text, email, number etc.)?
I cannot reproduce/confirm the problem. On any Visforms installation (testsystems and productive Website) the options visible for those field types, where they should be visible. So this sounds very strange.
Can you mail me a screenshot (contact@vi-solutions.de)?
  • Autor
  • Offline
8 Jahre 6 Monate her #4823 von michaelh@notabandoned.org
michaelh@notabandoned.org antwortete auf Bug: top field options like "hide label" do not appear
This reply gave me what I need. I did not realize that only certain fields had this option. I can confirm then that this is working as expected. thanks for the quick replyt
8 Jahre 6 Monate her #4824 von Administrator AV
You're welcome.
I'm glad to here, that there is no bug!
