Changing order of fields
13 Jahre 3 Monate her #139 von xtime123
Changing order of fields wurde erstellt von xtime123
Hello;
I am adding two new questions to an existing form, but see no way to order the questions. Do I have to recreate all the questions every time I want to add a new one or is there a way to change the order that I'm not seeing?
I don't have the form assigned to a menu, I'm using it in a module on all pages - Joomla 2.5.
Thanks!
Dave R
13 Jahre 3 Monate her #140 von Administrator AV
Administrator AV antwortete auf Re:Changing order of fields
Hi Dave,
you should be able to order the questions (fields). It works just like ordering in Joomla! 2.5 works.
You have to click on the label "Order By" in the header of the field-table. Thereafter you can change the order. You will see those blue-white arrows to move a field one position up or down. The input-fields with the order number in this table should be editiable to, after you have clicked on "Order By". You can use this input for changing the order as well.
After you are done, click on the save symbol in the table header (at the right side of the text "Order By").
Regards, Aicha
13 Jahre 3 Monate her #142 von xtime123
xtime123 antwortete auf Re:Changing order of fields
I tried that and it didn't work, but now it does! I must have clicked the wrong thing the first time.
Sorry to waste your time, and thanks for the quick response!
Dave
13 Jahre 3 Monate her #143 von Administrator AV
Hi Dave,
no problem. Your wellcome.
Kind Regards,
