Export Data problem
7 Jahre 5 Monate her #5892 von trail
Export Data problem wurde erstellt von trail
Hi ,
When i export data, iam getting a blank CSV file.
Any suggestion?
7 Jahre 5 Monate her #5894 von Administrator AV
Administrator AV antwortete auf Export Data problem - Bug in Visforms 3.12.3 beta
i guess you are using Visforms 3.12.3 beta
I just learned a few days ago, that there is a bug with the data export in Visforms 3.12.3 beta. I have already fixed it and it will be released with the next Visforms release.
The bug is easy to fix, because only 3 lines of code in one file are involved.
Open the file administrator\components\com_visforms\models\visdatas.php
Replace the code at line 408 - 410
$where = ' and c.includefieldonexport = 1'; $where .= (!(empty($params->exppublishfieldsonly))) ? ' and c.published = 1' : ''; $where .= " and c.typefield NOT in('submit', 'image', 'reset', 'fieldsep', 'pagebreak')";
with
$where = ' includefieldonexport = 1'; $where .= (!(empty($params->exppublishfieldsonly))) ? ' and published = 1' : ''; $where .= " and typefield NOT in('submit', 'image', 'reset', 'fieldsep', 'pagebreak')";
This should fix the problem.
If you are not using Visforms 3.12.3 beta, maybe you have not set up the export properly (record sets are not published and you have enabled the export option "published records only" or something like that). In this case please check out the documentation in order to set up the export properly: vi-solutions.de/en/documentations/visfor...rms/314-save-results
