Custom Validation Not Working
6 Jahre 6 Monate her - 6 Jahre 6 Monate her #6396 von Chicitadel
Custom Validation Not Working wurde erstellt von Chicitadel
Hello Admin,
I am trying to include a custom validation on some of the fields (email and phone number) thus far but noticed irrespective of the RegEx code used, the custom error text will just remain uncleared.
On a particular email field, I would want to restrict the input to only a particular domain, says example.com.
Note: all email usernames have two names separated by dot (.)
Regex tried are:
^\w+[.]+\w+[@][example[.][com]$
^\w+[.]+\w+[@][e][x][a][m][p][l][e][.][com]$
^\w+[.]\w+[@][e][x][a][m][p][l][e][.][com]$
^\w+[.]+\w+[@][e][x][a][m][p][l][e][.][c][o][m]$
^(\w+[.]+\w+[@][e][x][a][m][p][l][e][.][c][o][m])$
trying to validate
namea.nameb@example.com (for true)
and every other domain for false
The error remains
invalid input
On the phone field, I wanted to restrict input to the only French phone number
I tried the following
^([+][3][3][1-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9])$
trying to validate +33111111111 or +33999999999 (for true, and every other country code for false)
Outcome: All validation gives the same invalid input (false). irrespective of the input.
Visforms Version 3.12.10
On Joomla! 3.9.13
Letzte Änderung: 6 Jahre 6 Monate her von Chicitadel.
6 Jahre 6 Monate her #6398 von Administrator AV
Administrator AV antwortete auf Custom Validation Not Working
I set up a test environment with 2 fields
E-Mail field: Custom validation ^(\w+[.]+\w+[@][e][x][a][m][p][l][e][.][c][o][m])$
Text field: Custom validation ^([+][3][3][1-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9])$
When I enter namea.nameb@example.com into the e-Mail field, the regex validates to true. Other e-mails are not excepted
When I enter +33111111111 into the text field, the regex is validated to true. If I add an additional number, for example, I receive an "Invalid Input".
I'm sorry, I have no idea, why this is not working on your website. As many other people use custom validation without problems, I think this is not a problem with visForms but must be caused by some other circumstances which are individual to your website..
6 Jahre 6 Monate her #6399 von Chicitadel
Chicitadel antwortete auf Custom Validation Not Working
Thanks for the response admin,
I have tried tweaking some of the vis form field's setting but...
Do you think there is any other settings on visform field or advanced setting that must be set to true or false before using custom validation? Or any possible conditions?
Thanks
6 Jahre 6 Monate her #6401 von Administrator AV
the "invalide value" is the result of the browser site validation with javascript.
So this could be related to some javascript problem...
Folgende Benutzer bedankten sich: Chicitadel
6 Jahre 6 Monate her #6407 von Chicitadel
Thanks for the reply,
it worked now after updating to the beta version.
Additional observation why it may have not worked in the older visforms version could be related to the fact that I was using the custom validation for email on email field, and custom validation for phone on number field which may be creating additional validation behind the custom validation.
Thanks
