label issues
6 Jahre 7 Monate her #6698 von akshehu
label issues wurde erstellt von akshehu
Hi..
Please i have an issue, when form is to displaying front view, because my labels are long, it is not showing in one single line but will make it two lines.
How can this be adjusted so that labels will be in single column? and also can show properly.
i have tried two different template
i cant seem to attached image here
Thank you.
6 Jahre 7 Monate her #6699 von Administrator AV
Administrator AV antwortete auf label issues
what you can do about that and how you can do it, depends on the frontend template, which you use on your website.
Please check out the documentation www.vi-solutions.de/en/documentations/vi...layout-configuration in order learn more about the basic layout concepts of visForms.
Depending on your frontend template there may be additional information in the documentation i.e.: www.vi-solutions.de/en/documentations/do...ns/818-uikit-layouts if you use a uikit template or www.vi-solutions.de/en/documentations/do...-bootstrap-4-layouts if you use a bootstrap 4 template
6 Jahre 7 Monate her - 6 Jahre 7 Monate her #6700 von akshehu
akshehu antwortete auf label issues
Thank you for the explanation..
I am using Helix template, all works well except the front end display. I also installed the Helix Ultimate, and chose bootstrap 4, same issue. I also tried to change different layout. Hmm
So I try to use the Joomla protester template, I got same problem, here I conclude its the extension issues or i am missing something.
However, I was able to make this work well with the looks of the label output for the PDF front view , download. But the display of the data in front end not working as wanted.
Can you direct me the path, where i can increase the width of the Label of the Form so that it can show as as single line?
Appreciate.
Thanks
Letzte Änderung: 6 Jahre 7 Monate her von akshehu.
6 Jahre 7 Monate her #6708 von Administrator AV
I can set this up for you, but I have to charge for this sort of support with the individual configuration.
6 Jahre 7 Monate her #6711 von akshehu
Hello..
But its not a template issue,why do you have to charge..
I have tested indifferent template, same issue, so its from the extension.
If it were template issue than i can understand.
What i ask for is that the front view labels does not show in one line but rather make it two lines..
I hope you could understand and help please
see what i mean.
In diesem Beitrag ist für Gäste nicht alles sichtbar. Um alles zu sehen, muss man registriert und angemeldet sein.
6 Jahre 7 Monate her #6713 von Administrator AV
sometimes it is quite helpful to have a bit more information.
You are not talking about the field labels in the frontend form but about the field labels in the frontend data view and concrete in the detail view.
The data are simple displayed in a table.
The width of the table columns, if not specified further, are choosen "automatically" by the system, depending on how much content there is in the columns. As you have much content in the right column the system makes this column very big.
In your case you just have to add a bit of custom CSS to your Website like:
.vfdvlabel { width: 200px; }
This should fix the problem.
