Class 'ZipArchive' not found
6 Jahre 1 Monat her #7045 von djmelville
Class 'ZipArchive' not found wurde erstellt von djmelville
After applying the last several updates to Visforms the following error message appears:
An error has occurred.
0 Class 'ZipArchive' not found
However, the installation appears to be fine.
6 Jahre 1 Monat her #7046 von Administrator AV
Administrator AV antwortete auf Class 'ZipArchive' not found
thanks a lot for this notice!
This is really helpful.
It would explain, why sometimes the installation of the PDF-Fonts fails - an error which has been reported on this forum once in a while.
See: www.vi-solutions.de/en/forum-index/19-jo...-helvetica-all-fonts
So maybe you should check, whether the PDF-Fonts are installed properly on your website and if not fix the problem following the instructions from the link above.
