Path with conditional fields
4 Jahre 11 Monate her #7512 von gigiograndi
Path with conditional fields wurde erstellt von gigiograndi
Hy,
A question (for me really complicate, because of my bad english):
Is possible to have a path of conditional fields and how to do that?
Es.: we've got a first select field with two chances:
  • Exclusive Transport
  • NON Exclusive transport.
If we choose one of the other type of transportation, the next step is a seletct (list fields) of vehicles. ES.:
  • Exclusive transport selected -> Minibus, 1/3 seats auto, 3/5 seats auto, Electric shuttle
  • NON Exclusive transport selected -> 2/4 seats auto, GPL shuttle, 12/24 seats Bus
Hope there is all clear.
This is the building site link Visform:  www.gruppotuvoni.it/tuvoni__2021/preventivi-e-prenotazioni
Best Regards
4 Jahre 11 Monate her #7513 von Administrator AV
Administrator AV antwortete auf Path with conditional fields
if you use the listbox field type you have to set up 3 fields.
1. Listbox to select the Export Type
2. Listbox to select vehicles for Export Type "Exclusive"
3 Listbox to select vehicles for Export Type "Non Exclusive"
In fields 2 and 3 you have to set the field option "Conditiona field". ( www.vi-solutions.de/en/documentations/vi...0-conditional-fields )
Alternatively you could use the sql listbox field type: www.vi-solutions.de/en/documentations/do...m-database-using-sql
This is a more developer near approach. In this case you could work with one Listbox to select vehicle but this is much more complicated to set up and requires knowledge in sql and a source in the database where the proper vehicle options are taken from.
