textarea does not display data in form with edit
4 Jahre 6 Monate her #7680 von janbulens
If i open a form with the menu:  form with edit, then the textarea does not display data. But when set in the basic field options HTML edit to off, then the data is displayed? Is this a bug?
I am using joomla 4
4 Jahre 6 Monate her #7681 von Administrator AV
Administrator AV antwortete auf textarea does not display data in form with edit
Hi, with regards to the fact, that you are on Joomla 4, this could be a bug. I have to take a look at this as soon as possible.
Regards, Aicha
4 Jahre 6 Monate her #7689 von Administrator AV
I took a look into this.
Yes, you found a bug in Visforms for Joomla! 4
I will fix this as soon as possible, but it may take a view days.
I'm sorry for your trouble!
4 Jahre 3 Monate her - 4 Jahre 3 Monate her #7857 von Administrator AV
Addendum:
The error regarding the 'HTML Editor' setting for the textarea was a bug in Visforms and was finally fixed on 03.11.2021 with Visforms 4.1.3.
Letzte Änderung: 4 Jahre 3 Monate her von Administrator AV.
