Wir machen vom 20.Dezember bis zum 12. Januar Betriebsferien.
Max Submissions per $user id
2 Jahre 9 Monate her - 2 Jahre 9 Monate her #9113 von NickPovey
Max Submissions per $user id wurde erstellt von NickPovey
Dear Ingmar,
I've very nearly got a very good solution to all of my requirements thanks to Visforms. I was especially excited to find that the PDF editor allowed me to create just the output needed.
I have one remaining wish currently and that is to limit the number of form submissions to one per Joomla user id. And to create a message to the user and hide the submit button, as the subscription "max submissions" enables, if they have already submitted a form.
However "max submissions" doesn't appear to recognise the individual user, merely the total number of submissions that have been made. Am I missing something?
Is this something that, once again, you may be able to suggest a solution for?
Thank you
Nick
Letzte Änderung: 2 Jahre 9 Monate her von NickPovey.
2 Jahre 9 Monate her #9123 von Administrator IV
Administrator IV antwortete auf Max Submissions per $user id
Dear Nick,
I am very pleased that the PDF feature is also serving you so well .
And also that you were able to create a very good solution for all your requirements with Visforms.
The "max submissions" setting actually only counts the number of successfully submitted forms.
You want to use a different setting.
The feature is described in the documentation.
Display an edit link instead of the form:
docs.joomla-4.visforms.vi-solutions.de/e...ink-instead-of-form/
Citation:
It is often desired that a user should only be able to fill out and submit a form once.
Kind regards, Ingmar
2 Jahre 9 Monate her #9126 von NickPovey
NickPovey antwortete auf Max Submissions per $user id
Thank you Ingmar,
I'll need to think a bit about this, our currently proposed process means that we add additional data after submission and wouldn't want to expose that to editing. Some compromise may be required!
Nick
2 Jahre 9 Monate her #9130 von Administrator IV
Dear Nick,
at the moment sending the form once is linked to displaying the edit link.
The name is accordingly 'Display edit link instead of form'.
This is actually an unnecessary restriction for you, which we would like to remove.
We would like to separate the sending once from the question of what is then displayed or executed instead of the form.
Issue [VF-775] Forum: Add Feature: submit form once
2 Jahre 9 Monate her - 2 Jahre 9 Monate her #9131 von MaliRaj
MaliRaj antwortete auf Max Submissions per $user id
Da hänge ich mich wieder mit rein. Diesmal aber nur, um die Release-Info nicht zu verpassen. Das Thema interessiert mich auch, siehe mein Beitrag:
vi-solutions.de/de/support/forum/19-joom...-mal-ausfuellen-kann
Letzte Änderung: 2 Jahre 9 Monate her von MaliRaj.
2 Jahre 9 Monate her #9133 von NickPovey
Thank you Ingmar,
I like the Max Submissions options. If that had the option to select Max Submissions "per form" or "per registered user" and then the option "Display Edit Link - Yes/No" I for one would be very happy!
My wish was to present the user with a message like "You have submitted an entry, if your require to make changes please email"  and hide the submit button.
All very much appreciated,
Nick
