Max Submissions per $user id
3 Jahre 5 Monate her #9136 von Administrator IV
Administrator IV antwortete auf Max Submissions per $user id
Hello Nick,
Thank you for the detailed description of how you imagined your solution.
And thank you for your specific suggestion.
It is not yet entirely clear how we will best and ultimately implement the innovations.
Two points are obviously affected, which cannot be seen completely separately from each other:
Area 1 - 'Max once' with message or 'Max once' with message and edit link
Area 2 - 'Max Submissions' per form or per registered user (plus the option 'Display Edit Link - Yes/No')
Regarding area 1:
There is already the above issue (775) for this.
This is pretty much what Heinz described in his post.
Thanks to Heinz for the link to his original post.
We also consider 3 alternative reactions (instead of displaying the form) to be sensible here:
- Notification to the user
- Message to the user with edit link
- Redirect URL
Regarding area 2:
I have created a separate issue for the development wish list (777).
One reason was to be able to keep the two points project-technically separate at this point.
Issue [VF-777] Forum: Enhance Feature: Max Submissions: count per registered user
We now have to think a little more about whether we can possibly combine the two points and implement it optimally.
Suggestions and ideas are always very welcome.
Kind regards, Ingmar
3 Jahre 5 Monate her #9137 von Administrator IV
Dear Nick,
there is a pretty simple workaround for you.
At least for the meantime, until the feature is released.
You just need to add some JavaScript to the form.
Step 1: Configure 'Display an edit link instead of the form'.
docs.joomla-4.visforms.vi-solutions.de/e...ink-instead-of-form/
Step 2. Add a (invisible) site module to the page with the form.
This is described in the documentation.
Load JavaScript via a custom module:
docs.joomla-4.visforms.vi-solutions.de/e...d-script-own-module/
Step 3: Paste the following small JavaScript into the module.
<script>      jQuery(document).ready(function() {          // console.log('module started');          jQuery('#visformcontainer.visforms-form:not(.visforms)').empty().append('<p>You have submitted an entry, if your require to make changes please email.</p>');      }); </script>
I tested the Code with the UI framework 'Boostrap 5'.
Step 4: Done.
The user gets his page with the edit link.
The edit link is completely removed from the page along with the message text.
Instead, your new text from the 'append()' call will be inserted.
3 Jahre 1 Monat her - 3 Jahre 1 Monat her #9556 von Administrator IV
Hello Nick,
the new feature is included in the latest release from 22.05.2023 for Joomla 4:
Visforms 4.3.0
docs.joomla-4.visforms.vi-solutions.de/e...dates/version-4-3-0/
Visforms Subscription 4.3.0
docs.joomla-4.visforms.vi-solutions.de/e...s/sub-version-4-3-0/
The documentation has been changed accordingly in the following section.
Maximum one form submission:
Letzte Änderung: 3 Jahre 1 Monat her von Administrator IV.
