Field sort order not sorting
12 Jahre 3 Monate her #599 von JohnDough
Field sort order not sorting wurde erstellt von JohnDough
Once one has created a form and then want to move a field up or down in the sort order it moves it on the backend but not on the published form.
It seems that the order is set to remain in the order that the fields were created in.
One has to either plan your fields in advance before creating them or delete fields and add new fields to get the published order correct.
Amateur "Bug" Writer
12 Jahre 3 Monate her #600 von Administrator AV
Administrator AV antwortete auf Field sort order not sorting
Hi JohnDough,
if you change the field order backend (fieldlist), this affects the field order in frontend (published form) as well. (And in Data views).
You have to click on the small symbol with the double arrows (in the header of the first column). Then you can drag and drop the field (click on the three squares an drag the line with the mouse still pushed).
Go to frontend and refresh the form.
If that is not working I could take a look at it.
Kind Regards,
12 Jahre 3 Monate her #601 von JohnDough
JohnDough antwortete auf Field sort order not sorting
Hi Aicha
It is not working on my side, you still have access to the back end and are more than welcome to check it there.
Cheers
John
12 Jahre 3 Monate her #604 von Administrator AV
Hi John,
will take a look at it tomorrow. Which fields do you want to be moved and where? (you can send me that via mail).
Kind Regards and a some more nice weekend hours.
12 Jahre 3 Monate her #607 von Administrator AV
Hi John,
I just took a look into the administration of your website. Here is what I found.
When I try to change the field order it looks in the backend as if the field is moved but when you browse away from the fields list view and return to it you can see, that the changes were not really stored in database.
Visforms uses the default Joomla! functions and mechanisms to move fields (change order of recordsets). So I tested with the articles view. Same problem there. You cannot change order of articels in a category.
So this is not a problem of Visforms but of your Joomla! administration at all.
At the moment I have no real idea where this could come from and I haven't had time yet to ask Google.
I'll stay in touch.
Kind Regards,
Folgende Benutzer bedankten sich: JohnDough
12 Jahre 3 Monate her #609 von JohnDough
Hi Aicha
Thanks for the feedback, it is not serious as I will just preplan any future forms properly. Maybe it will be fixed in an upcoming Joomla update. Once again, thank you for your professional service.
Cheers
John
