Emails not send
12 Jahre 2 Monate her #667 von bitfreak86
bitfreak86 antwortete auf Emails not send
Thank you, i've sent you an email with access info.
12 Jahre 2 Monate her #674 von Administrator AV
Administrator AV antwortete auf Emails not send
thanks for the login. I checked everything. Because both, the storing of user inputs in the database and the redirect of the form after successful form submit do work fine the only possible solution I can think of is, that the mailer on your websites doesn't work at all.
You could test this for example by enabling frontend user registration (just for testing) and try to register as a new user from frontend. This will use the mailer too, for sending a registration mail. I'm quite sure, this will not work too.
Kind Regards,
