Probleme with 2 subdomain "Cannot redeclare class"
11 Jahre 1 Monat her #1949 von Administrator AV
Administrator AV antwortete auf Probleme with 2 subdomain "Cannot redeclare class"
I would like to know, if the update fixed the problem.
So, did you see the update information in the administration of website and install it?
And did it fix the problem?
Thanks and Regards,
11 Jahre 3 Wochen her #1972 von csphoenix1
Hello :)
Sorry for my late i'm very busy in this time.
So, I updated the extension to 3.5.5.
About the refresh captcha button, when I click on the button, I see well a new mathematical image, and my answer is well recognise when I click on submit.
So this problem is solved :)
About the "form is missing" problem, the content's file I have modified (in the past) was not modified after the update. So this mean that my file and the file in the update are the same. In other words, the correction is well included in the update. So this part is OK too :)
About TinyMCE problem, he still delete the META balise and the <br /> balises :s
If I use the TOGGLE EDITOR button, the TinyMCE editor is well replaced, but the balises are no longer present (certainly due to TinyMCE editor which delete the balises during the page loading).
Except the TinyMCE problem, your update solve officialy all the other problems :)
Thank you.
11 Jahre 3 Wochen her #1974 von Administrator AV
thanks for the feed back.
I hope you can solve the editor problem, too.
