Edit form - required and textarea
10 Jahre 4 Monate her - 10 Jahre 4 Monate her #2988 von Seth
Edit form - required and textarea wurde erstellt von Seth
Hello,
please help me how can I change word Required to another word, and how can I change height and width on field textarea (its too big).
Thank you !
Letzte Änderung: 10 Jahre 4 Monate her von Seth.
10 Jahre 4 Monate her #2989 von Administrator AV
Administrator AV antwortete auf Edit form - required and textarea
the text "required" comes from the language files. Did you look, whether there are translations available for your language? www.vi-solutions.de/en/documentations/visforms/translations
Those translations are made by volunteers. I do not check their quality.
You can use the language manager to translate the text if nothing else works. How to translate a text from a language file is a standard Joomla! technique which has nothing to do with Visforms. So please check the Joomla! documentation if you do not know how this is done.
Fields of type "textarea" have an option "Rows". You can set this option for example to "5". The textarea should be less high then.
