First Steps
This is legacy documentation for old versions of the plugin as shipped with Visforms Subscription prior to version 3.2.2. In newer versions, individual success pages are configured directly in form fields with option lists.
We suggest reading the documentation from the beginning, starting with the Introduction. We will not repeat explanations that help you to better understand the whole context.
Enable plugin in plugin manager
Please make sure, that you have installed your Visforms Subcription. After that, you have to enable the plugin in the plugin manager before you can use it.
Go to the Administration Panel of your Joomla! installation and click the top menu item "Extensions" and then "Plugin Manager". Search for the list item with the name "Visforms Plugin - Custom Redirects". You can use the search filter above the list. Make sure the plugin "Status" is set to enabled.
Configure Redirects Settings
After you have made these basic settings, please go to the form configuration where you will find a new tab "Custom Redirects", where you can set up your custom redirects for each form individually.
These basic settings covered please read the article about the custom redirects configuration.
Article list Find suitable subscription
