Component error notice
13 years 4 weeks ago #245 by jk1
Component error notice was created by jk1
I just updated spambotcheck to the latest version on one of my local test sites, after I noticed that a new version is available in the Joomla backend.
It's on Joomla 2.5.14 and php 5.3.1. Clicking on the spambotcheck component throws an error:
( ! ) Notice: Undefined index: 1 in ...\administrator\components\com_spambotcheck\models\users.php on line 436
Call Stack
# Time Memory Function Location
1 0.0007 331744 {main}( ) ..\index.php:0
2 0.2387 6010768 JAdministrator->dispatch( ) ..\index.php:46
3 0.2519 6405976 JComponentHelper::renderComponent( ) ..\application.php:153
4 0.2803 6422688 JComponentHelper::executeComponent( ) ..\helper.php:351
5 0.2815 6484552 require_once( '...\administrator\components\com_spambotcheck\spambotcheck.php' ) ..\helper.php:383
6 0.3083 6852528 JController->execute( ) ..\spambotcheck.php:44
7 0.3084 6852576 SpambotcheckController->display( ) ..\controller.php:761
8 0.3122 6915416 JController->display( ) ..\controller.php:50
9 0.3354 7753400 SpambotcheckViewUsers->display( ) ..\controller.php:722
10 0.3355 7753512 JView->get( ) ..\view.html.php:42
11 0.3355 7753632 SpambotcheckModelUsers->getItems( ) ..\view.php:386
( ! ) Notice: Trying to get property of non-object in ...\administrator\components\com_spambotcheck\models\users.php on line 436
13 years 4 weeks ago #246 by Administrator AV
Replied by Administrator AV on topic Re:Component error notice
Hi jk1,
thanks so much for that information. I just noticed, that I hadn't all "developer" messages enabled in php.ini on my develop system.
I will make an update, that will fix the error as soon as possilbe.
You can fix it yourself.
Open administrator/components/com_spambotcheck/models/users.php
Replace the content of line 436 which is
$item->group_count = $userGroups[$item->id]->group_count;
with
$item->group_count = $userGroups[$item->user_id]->group_count;
That should fix it.
Kind regards,
13 years 4 weeks ago #249 by jk1
Replied by jk1 on topic Re:Component error notice
Yes, it does fix that typo :)
13 years 3 weeks ago #256 by Administrator AV
Replied by Administrator AV on topic Aw: Re:Component error notice
Hi jk1,
I found some more warnings and made a new update. Did you see it in extensions->updates?
Does it work properly now?
