How to check and test the list of current users
13 years 9 months ago - 13 years 9 months ago #72 by meto
hello all,
I want to thank you very much about this good plugin.
I have a very serious question:
I have in my site about 3500 users. And I have installed the plugin (spambotcheck) after this number of users. And I'm very sure, that I have in my user list so many spam registered users. How can I check the list of users (3500 registered users) and pure it from spam??
How can I found the spam registered users ?? I have checked the list manually before, and I found many spam users.
Please I need help !!
Any Ideas about that ??
Many thanks !!
Last edit: 13 years 9 months ago by meto.
13 years 9 months ago #73 by meto
Any Ideas ??
I need help please !!
13 years 9 months ago #74 by Administrator AV
Replied by Administrator AV on topic Aw: Re:How to check and test the list of current users
I'm sorry but the plugin is only for protection not for tidying up.
I don't know exactly why you want (nned) to delete spam user from your user list. Even if you have spam user in your user list, using the plugin, they will not be able to login on your website and your site is secured.
But if you really have to find the spammer on your list, I think you have to do this manually.
You can gain some furter information from the plugin. If you enable the parameter "log spammer to db" you may retrieve information about users who are allready in your user list and who are prevented from login for the action (login/registration) is also monitored in the databasetable. But you have to delete those users manually in the user list and you would only find those spammers who try to login on your webside.
If you need to find all spam user in your lsit, you have to check the users on your list manually, for example on the website of stopforumspam.com
Hope I could help,
regards,
13 years 9 months ago #75 by meto
Thanks for your reply.
I did it before manually using stopforumspam.com.It is very good site. But this operation take more time and it is very trying.
But are sure, that those registered spammer in users list can not login in m site ?
13 years 9 months ago #76 by Administrator AV
I'm sure.
You just have to enable the plugin parameter "event to monitor" = Registration and login
and use the normal Joomla! Login.
Regards, Aicha
13 years 9 months ago #77 by meto
Ok Thank you ...
Last question please:
I want to be notified with all updates for the plugin, what should I do ?
