Component/Settings
10 years 11 months ago #2287 by CleverTitania
Component/Settings was created by CleverTitania
OK, I'm not any expert on Joomla (I've used Memberclicks custom built version for work for years, and now I'm trying to learn to run the open source version on my site), but I've done a lot of searching online and on this forum, and I'm not finding the answer to my question. So sorry if this is a duh moment.
I recently installed SpamBotCheck because I got nailed by 30k spam users clogging up my site. The description of the plugin says a Component comes built in, which can be used to better manage your users/spam bots, and to see the Component Manager.
But, while some people refer to different extensions and plugins by the phrase, as far as I can tell there is no Component Manager in Joomla, and nothing which mentions SpamBotCheck is anywhere in my component menu. And nothing about this plugin has been added to my User menu or the User Management page. In fact, the only place I can find any evidence of this plugin is in the Plugin management screen. So what am I missing here?
Thanks in advance. :)
10 years 11 months ago #2288 by Administrator AV
Replied by Administrator AV on topic Component/Settings
I'm quite exact about the terms "component", "plugin", "module", "template" or "extension" which would cover all 4.
If you are using Joomla! 3.x you should see an entry "Spambotcheck" in the submenu of components menu in the adminstration panel of your website (assuming you are a Super User).
10 years 10 months ago #2289 by CleverTitania
Replied by CleverTitania on topic Component/Settings
I am the only user, and yes a Super User. I have no Spambotcheck listed anywhere in my Components menu. That's the first place I looked - I only mentioned the Component Manager because it was in the documentation within the plugin.
10 years 10 months ago #2292 by Administrator AV
that is very strange.
What ist your Joomla! Version on what is the plugin Version?
The component is part of the installation package since 1.1 11 (Joomla! 2.5) and 1.3.11 (Joomla! 3.x).
In the component you can see a list of spambot attempts which are logged to the database (if this option is set to yes in the plugin configuration). Further on you can set users to trusted, which will allow them to login, even if they are listed in any of the only spambot databases used by the plugin.
I sometimes hve had a problem with the record sets in the menu table when I worked on Joomla! installations which were updated from Joomla! 1.5 to 2.5 or 3. The values in fields 'lft' and 'rgt' were messed up a bit and that resulted in missing menu items (in the administration panel).
