Conditional field does not work
10 years 1 month ago #3362 by Faberjack
Conditional field does not work was created by Faberjack
Hi, while I build the form, suddenly conditional fields associated with the selected field are no longer visible. Those made previously continue to operate, the next not. I checked the NRL database queries and there is nothing different between the previous and current. And I did not install any new component. The inspection does not highlight any malfunction of the page.
I am going crazy.
What should I do?
10 years 1 month ago #3367 by Administrator AV
Replied by Administrator AV on topic Conditional field does not work
this sounds to me like a side effect of some caching.
Usually all changes made in the form configuration are visible at once on the website but maybe if you have the cache enabled...
Hiding and displaying the conditional fields is achieved with Javascript and this script is different, if you add more conditional fields, so maybe the old script is cached on the browser....
The session can be a point of caching, too. This will be cleared, if you log out or if you close the browser completely.
