Visforms On Mobile
9 years 10 months ago #3640 by perryworld
Visforms On Mobile was created by perryworld
Hi
We are new to using Visforms and really like it and how easy it is to use.
We have a question when displaying the form on an iPhone.
If we have a dropdown as one of the fields on the form, it shows the options fine in the list of options but when we select an option it only shows the very top of the words in the box so you cannot actually see what you have chosen.
Is this something you can help us with?
Thanks
Richard
9 years 10 months ago #3645 by Administrator AV
Replied by Administrator AV on topic Visforms On Mobile
Hi Richard,
I have not heard of this problem before but I think it is a CSS problem.
Although I provide responsive layouts for the forms (Boostrap 2.3.2 compatible HTML), Visforms basically uses the CSS of your template for the styling.
9 years 10 months ago #3646 by perryworld
Replied by perryworld on topic Visforms On Mobile
Hi Aicha
Thanks for your reply, we will take a look at our template to see what is causing the problem.
Cheers
Richard
