visforms joomla 3.6. error 1305 - FUNCTION medimix.CHAR_LENGTH does not exist SQ
9 years 10 months ago #3695 by medimix
Getting this message in error page after submitting form
1305 - FUNCTION medimix.CHAR_LENGTH does not exist SQL=SELECT CASE WHEN CHAR_LENGTH (name) THEN CONCAT_WS(":", id, name) ELSE id END as slug FROM #__visforms
emails are sent OK so far.
My configuration:
Joomla 3.6.4
visForms 3.7.10
bought plug-in multiple email addresses, enabled with blank config
mySQL 5.0.95
PHP 5.3.29
Any input?
9 years 10 months ago #3696 by Administrator AV
actually I made a post about this topic just two days ago.
www.vi-solutions.de/en/forum-index/19-jo...ength-does-not-exist
Could you please test the fix and let me know if it works?
The following user(s) said Thank You: medimix
9 years 10 months ago #3702 by medimix
I applied the patch and the error is gone.
Thank you so much! : D
Carlos
9 years 10 months ago #3703 by Administrator AV
Hi Carlos,
you're welcome and thanks for posting back, that it works!
Kind Regards,
