VisForms and plugin
9 years 7 months ago #3915 by Coin
VisForms and plugin was created by Coin
i would like to show form in an article. I have created a form with fields with ID=1 i put the string {vfformview}{"formid":"1"}{/vfformview} in the place of where i want to show form, but it is not working.
Any suggestion?
9 years 7 months ago #3916 by Administrator AV
Replied by Administrator AV on topic VisForms and plugin
Is the content plugin visforms form view enabled?
Is this a Joomla! article or is the article created with some thirdparty extension? Then it will only work, if the extension supports the use of content plugins and the use of content plugins is enable for the extension/the article (i.e. K2 articles).
9 years 7 months ago #3917 by Coin
Replied by Coin on topic VisForms and plugin
Thanks for the fast reply.
The articles is a was made directly with Joomla! and the pluging in enable in the plugins menù.
This is my html code for the articles:
<p style="text-align: center;">MARCO BARDI CONTATTI</p>
<p>&nbsp;</p>
<p>Si pu&ograve; contattare Marco Bardi in pi&ugrave; modi. Uno dei pi&ugrave; semplici &egrave; cliccare qui a destra sull'ICONA della sua PAGINA FACEBOOK e scrivergli un messaggio.</p>
<p>Sempre sulla destra c'&egrave; anche l'icona del suo CANALE VIDEO dove anche in questo caso si potr&agrave; scrivere un messaggio.</p>
<p>Per contatti via mail si consiglia di SCRIVERE nel seguente FORM:</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<table style="width: 701px; height: 21px;">
<tbody>
<tr>
<td>&nbsp;</td>
<td>&nbsp;<img src="images/MB.JPG" alt="MB" width="567" height="361" /></td>
<td>&nbsp;</td>
</tr>
</tbody>
</table>
but the page display as this:
www.marcobardi.com/index.php/8-profilo/71-contatta-marco
I can't understand why it isn't working...
9 years 7 months ago #3918 by Administrator AV
the plugin string is correct. When I enter it on my test website, where I have a form with the id 1, this form is displayed.
If the string syntax is correct but the string is not replaced, this indicates, that the plugin does not start working.
The only reason I know, why the plugin does not start working is, that it is not enabled or that because of the configuration of your website content plugins are not "triggered" on the article, as they should by default.
Usually with a Joomla! article, content plugins are always triggered but maybe you have a third party extension on your website that prevents, that the content plugins are triggered or maybe it is a setting in your template....., maybe it is a cache problem.
In order to debug this problem, the best way is, to disable third party extensions (plugins, modules..) and test with the Joomla! default template Protostar. If it works then, step by step go back to your template and enable the third party extensions again until you find the problem.
