Visualizzare dati su Visform / Display data also Visform to correct
9 years 6 months ago #4090 by marcolino21
Salve,
ho creato una form con dei campi creati con il componente Visform; questi dati sono sottomessi dall'utente e quindi su una pagina legata al suo profilo.
Dopo aver sottomesso i dati, voglio dare la possibilità all'utente di poterli vedere (ma solo i suoi inseriti).
Come faccio?
Grazie
Saluti
Modifica post
I created a form with the fields created with Visform component; these data are submitted by the user and then on a tied to his profile page.
After submitting the data, I want to give the user a chance to see them (but only its input).
How can I do?
Thank you
Greetings
Edit posts
9 years 6 months ago #4091 by Administrator AV
at the moment this is not possible straight away. But this will be a feature of the next Visforms Subscription.
There will be a form option in the "Frontend data view" tab "Own records only". If it is enabled, users can always only see there own data. And there will be a new menu item type "My Submissions" which will allow you to display the submissions of all forms of the logged in user. (This is of interest, if you have more than one form and want to display all submissions of the user on one page).
I hope that I can release the subscription with these new features this month.
9 years 6 months ago - 9 years 6 months ago #4102 by marcolino21
Only to see the user's data online, I can see a new formdata frontendq on another menu item and change the code so that when you make a query with the list, the filter also id user online ? How can I do? the user needs at least to see only its input. You can come to my rescue even with the code? thank you (its Urgently)
PS .: perst answer please. Thank you
Italian Version
Solo per visualizzare i dati dell'utente in linea, io posso inserire un nuovo FormData frontendq su un'altra voce di menù e modificare il codice in modo tale che quando fare la query con l'elenco, filtro anche l'id user in linea ? Io come posso fare ? l'utente ha bisogno almeno di vedere soltanto i suoi dati immessi. Potete venirmi in soccorso magari con il codice ? grazie
PS.: rispondete prest per favore. Grazie
Last edit: 9 years 6 months ago by marcolino21.
9 years 6 months ago #4104 by Administrator AV
as I wrote, this will be a feature of the next release of the Visforms subscription.
The feature is already implemented and I have also run some test but it will take me some further time until I publish the release.
if you would buy a subscription I could send you a pre release of the version were the feature (own data only) is implemented. It is more like beta but maybe this would be a good solution for you (no extra coding..).
9 years 5 months ago #4152 by Administrator AV
I just wanted to let you know that I have released the Visforms Subscription 1.2.2 last week.
There a two major new features included with it.
1. New frontend view "My Subsmissions". See www.vi-solutions.de/en/documentations/vf...n/685-my-submissions
2. New feature (form option for the data view in frontend) with which you can control that only own records of the currently logged in user are visible. See www.vi-solutions.de/en/documentations/vi...rms/314-save-results and www.vi-solutions.de/en/documentations/vi...er-inputs-in-frotend
