Field order
9 years 1 week ago #4649 by envisys
Field order was created by envisys
How can I change field order in a form?
9 years 1 week ago #4650 by Administrator AV
Replied by Administrator AV on topic Field order
Visforms uses the Joomla! standard way for ordering fields. (It is just like changing the order of Joomla! articles in the Content -> Articles view for example.)
Click the table header of the ordering column (leftmost column in the view, two small triangles) and than change the field order with drag & drop.
9 years 1 week ago #4651 by envisys
Replied by envisys on topic Field order
I tried but It don't work.
I see the tolltip that inform you about drug and drop function, but It don't work. I Just can select some text.
9 years 1 week ago #4652 by Administrator AV
The tooltips are always visible but if you actually want to change the sort order, you must click the table header first. Those three stacked squares in each "field" row, will then change color to black. Before you have clicked the proper table header, they are gray (= disabled).
9 years 1 week ago #4657 by envisys
My fault... you are right! (>_<)
Now it works
