Add field
9 years 1 week ago #4653 by GABI77
Add field was created by GABI77
Hi
I would like insert a filed between two other field.
If I understodd correctly, all fileds are display by "ID in forms" by I don't find any solution for insert a new field between id forms 4 and id form 5.
Could you help me ?
Thank
9 years 1 week ago #4654 by Administrator AV
Replied by Administrator AV on topic Add field
Fields are not displayed by id but by field order.
You change the field order any time.
Only if you have not changed the field order yet, order and id-order are simply the same.
Ordering fields works just like ordering Joomla! articles (for example). Use the field order column in the fields list view in the administration (first column in this view).
See also: www.vi-solutions.de/en/forum-index/17-jo...ons/1337-field-order
9 years 1 week ago #4655 by GABI77
Replied by GABI77 on topic Add field
Thank , it's working but is not usy to find
9 years 1 week ago #4656 by Administrator AV
If you are familiar with Joomla! administration this should be quite easy to see and obvious, because it is just Joomla! standard and nothing special with Visforms.
